Unigine Valley 1.0 Benchmark
Publisher: Unigine
Unigine's free Valley 1.0 benchmarking tool is incredibly taxing on the GPU whilst placing the CPU under very little stress, making it a great indicator of pure GPU grunt. It should also, therefore, be repeatable for most users running half decent systems.
We run the full benchmark at 2,560 x 1,600,with Ultra detail. The strongly coloured bars show the results at what we would consider the most sensible settings - with the case opening uncovered and with the fan in either 40% or 55% mode. The blue bar shows the result from a cold start.
        AMD Radeon R9 290X - 40% fan, covered
        AMD Radeon R9 290X - 55% fan, covered
        AMD Radeon R9 290X - 40% fan, uncovered
        Nvidia GeForce GTX 780 3GB - covered
        AMD Radeon R9 290X - 100% fan, covered
        AMD Radeon R9 290X - 55% fan, uncovered
        Nvidia GeForce GTX 780 3GB - uncovered
        AMD Radeon R9 290X - 100% fan, uncovered
        AMD Radeon R9 290X - 55% fan, baseline
            1665
            1951
            1960
            2069
            2102
            2142
            2154
            2160
            2166
    Score (higher is better)
Noise
We measured the noise generated by the fan of each GPU using a decibel meter pointed at the side panel of the system at a distance of 30cm. The ambient noise level with the system off was 38dB. The fans of both the 290X and GTX 780 idled at 20% according to GPU-Z.
        Ambient
        Nvidia GeForce GTX 780 3GB - idling (20%)
        AMD Radeon R9 290X - idling (20%)
            38
            41
            42
            43
            45
            46
            47
            50
            52
            54
            64
    Noise in dB
Heat
The 290X is designed to run at 95C so it theoretically shouldn't waver from this temperature when under load. However, we took a temperature reading of the GPU anyway to see how it compared to the GTX 780. As ever we have calculated this as a Delta relative to the ambient room temperature, which on this day was 26C.
        AMD Radeon R9 290X 4GB - 40% fan, uncovered
        AMD Radeon R9 290X 4GB - 40% fan, covered
        AMD Radeon R9 290X 4GB - 55% fan, uncovered
        AMD Radeon R9 290X 4GB - 55% fan, covered
        AMD Radeon R9 290X 4GB - 100% fan, uncovered
        AMD Radeon R9 290X 4GB - 100% fan, covered
    Delta T in °C
